Fast Injectors?
Old 03-03-2016, 05:12 PM
MikeD.'s Avatar
Default Fast Injectors?
So im looking for some injectors for my truck, minimum 60lb. I see that FAST offers 85Lb LS2 injectors for 375, whats the consensus on these? I can tell there just a modified bosch injector. FIC offers the 60lb and 72lb for much more, which are also modified versions. Seems I can get more injector for less, but that doesnt make sense.
What about siemens? They seem to be affordable also. ID's are just way out of my price range.
Im currently running 52lb GT500 injectors at 115% making 581rw on 7psi
Old 03-03-2016, 08:53 PM
charcoal03silvy's Avatar
FAST = JUNK
Seriously, tuners should charge people more for using shitty injectors.
Siemens aren't the greatest but they work a lot better than the FAST stuff. FIC seem to be decent. Also look into Deatschwerks.
Old 05-12-2016, 10:22 AM
renright83's Avatar
What would u recomend since fast are junk?
Old 05-12-2016, 10:40 AM
Three6GMC's Avatar
I used FAST 85 lb injectors on my 5.3/turbo and 6.2/turbo and they idled smooth with no issues i don't see how you say they are junk. I have used them on several other builds as well. For the money they are good injectors and be just fine for your setup. FIC are good just re done Bosch injectors like the IDs.
Old 05-12-2016, 10:43 AM
renright83's Avatar
Yea 800+ for injectors on a 5 to 600 hp engine seems disturbing
Old 05-12-2016, 10:48 AM
FFDP's Avatar
Deatschwerks makes a 60lb injector for a decent price. Should be good for the 500-600hp on pump gas. I don't have a vehicle with this much hp to confirm but I've seen 80lb go upwards of 700-750hp.
2000-06 | DeatschWerks
Old 05-12-2016, 10:49 AM
Three6GMC's Avatar
you will be fine with the FAST injectors. I put like 20k miles on mine with zero issues and they idled perfect and ran great. Not to mention the other builds I have used them on. I guess my tuner is just good at what he does.
Old 05-12-2016, 11:03 AM
renright83's Avatar
Where's the best place to but the fast injectors
Old 05-12-2016, 11:06 AM
Three6GMC's Avatar
Jegs is pretty quick and usually around the $380 range
Old 05-12-2016, 11:07 AM
renright83's Avatar
Hell yea that's not a bad deal my budget build is looking even better lol
Quick Reply: Fast Injectors?
