Fuel Pressure loss
Fuel Pressure loss
So im having a fuel pressure issue with my return style fuel system on a NNBS. To start off i ran the truck for the first time under boost the other day and all seemed to be fine and the pressure stayed around 58-62 psi of pressure. Then yesterday i went to do some more tuning and got into boost and loss all fuel pressure down to 20 psi. Now truck wont even crank only builds about 6 psi of pressure. The fuel system consist of a walbro 450 in a stock gutted bucket with a hot wire kit. Truck has a external FPR at the front of the truck as well. Also it does have fpcm and im still unlcear of how to get rid of the fpcm with using the hotwire kit becuase i still have the fpcm plugged in along with the fuses. My questions is there any known issues i could check before dropping the tank back out again? Im thinking it could be a loose AN fitting in the tank but wanted to know if there was anyhting to try before checking that
found the problem the gates 5/16 submersible hose had blown out at the fitting not sure why it did this but reran a new piece and if it happens again will have to go a different route
bisqikss
04-30-2020 09:05 AM
tim wellington
03-01-2016 11:11 PM
