Which fuel pressure regulator?
Old 05-13-2012, 08:26 PM
oakley6575's Avatar
Default Which fuel pressure regulator?
Hey guys! I need to finally get my fuel system where it should be. My truck came stock with a return system and when I put the LS3 intake on, I've been running the stock returnless fuel rail. So needless to say, I need to get some new rails.
I've been looking at the black Holley EFI rails. They are the only black rails I can find. Anyways, the system should run: tank>pump>line>injectors>fpr>return line. What fuel regulator are you guy running or would recommend for this set up? Thanks
Old 05-13-2012, 08:47 PM
Baltimore Whore
Mangled03gmc's Avatar
I picked up a fuel lab FPR. Seems they make a very nice piece. There is more then 1 way you can run it, but consensus is tank to the rails, out of the rails to the Fpr then return to tank. Also some people run a y to each each fuel rail, but it can also feed into one then cross over( F bodys, vettes cam factory that way
Old 05-13-2012, 09:12 PM
oakley6575's Avatar
Those do look pretty nice. Do I block the outlet port so all the fuel runs out of the return?
Old 05-13-2012, 09:33 PM
Un-Registered User
mcfarlnd's Avatar
i got a SX regulator. havent used it, still working on the motor, it looks nice. you put the regulator inline.... why would you want to block the outlet?
Old 05-13-2012, 09:45 PM
oakley6575's Avatar
Because if the regulator is after the rails, there is no reason for an outlet. The rails would have already been feed, so at that point, I would just be returning fuel to the tank.
Old 05-13-2012, 10:03 PM
oakley6575's Avatar
Something like #2
Old 05-13-2012, 10:04 PM
Un-Registered User
mcfarlnd's Avatar
never seen it like that. ive always seen them between the two rails or before the rails. Havent seen the at the end of the system. Dont see why it wouldnt work tho, just curious.
Old 05-13-2012, 10:09 PM
Un-Registered User
mcfarlnd's Avatar
interested to see if it will work like that.
Old 05-13-2012, 10:11 PM
oakley6575's Avatar
From what I've read, everything says it's best to place the regulator after the rails in a return system. But I haven't seen anyone show how they plumbed it. So I'm not sure..
Old 05-13-2012, 10:15 PM
Baltimore Whore
https://www.performancetrucks.net/fo...r-479271/phump
Quick Reply: Which fuel pressure regulator?
