Fuel pump and injector help needed
I have a MP112 going on my 2004 Sierra and needing help with fuel pump upgrade and injector sizing. I’m shooting for 500 crank HP. The supercharger kit came with 42LB injectors. Will these be big enough. Also, what pump should I upgrade to. Thanks
I ran the 8.1 marines (I assume that is what you have) for a while on mine at lower boost levels with a Walbro GSS340 (255lph). When I started pushing it, I swapped to Deatschwerks 60lb (72lb at our pressures). I’m still running the same fuel pump, with a Kenne Bell Boost-a-Pump. I am at the limits of it, and will go to a Walbro 450lph or 525lph if I push it further.
From what I recall, the 340 is a direct drop-in. It will play nice with the regulator in the fuel module. If you start upping the boost, you will likely see some pressure drop at high RPMs, but it can still work fine. I would likely do a hotwire upgrade for the pump - either Racetronix or make your own.
Look up the other BigKID’s build thread - you’ll like it.
BIG_KID (10-11-2024)
maxspeed05V
07-05-2016 06:40 PM
Silver-Dollar
11-21-2008 10:12 PM
