Fuel pump and injectors for e85
Yea I took that chart and converted it to volumetric flow to use in my spreadsheet in the sticky thread in this section, which is where I got all my numbers. Its odd because most fuel pumps are rated in volume not mass, but its not a huge deal.
Yea you would run them in parallel, and if it were me I would hard wire one pump on, and have the controller mess with the second pump only.
A lot of injectors (and pumps) don't like being above a certain pressure (80psi is a popular limit). So if you can get away with a low rail pressure, like 40-50psi, then do that so you can stretch your fuel components to more boost.
I agree on using a better turbo for that...I wanted to try a GT5518 at one point, would be a pretty good match for what you are wanting I think.
Formerly ScreamingL
Youll have to decide is it time for low impedence or pay huge money for ID2000s
If you have holley then the low impedence is a no brainer
At that point you have
Billet atomizers
Holley injectors
Siemens
Bosch
My 225s were far cheaper then ID2000s even with me buying a driver
Billet atomizers
Holley injectors
Siemens
Bosch
Billet atomizers
Holley injectors
Siemens
Bosch
Billet atomizers
Holley injectors
Siemens
Bosch
i know this is off topic but atomic you mentioned the gt5518r and after looking around m liking the gt5533r-2 which is the 94mm. what is yalls opinions and what do you think for the turbine a/r 1.4 maybe? im wanting 1200whp out of the 408 on e85
