Fuel Pump Wiring
#23
Some people like clean installations using factory wiring, others like to use romex and zip tie to a bundle that already contains the correct wire(s) to make a clean factory looking install.
The 7 pin trailer wiring does contain an aux that can use used, autozone has great wiring diagrams for the price of on the house. I think it's 10 or 12ga on my 03 with trailer tow package.
You could even re-pin your existing FP relay in the fusebox to use the larger wire from the trailer AUX, making for a very clean installation. You can buy the individual micropack pins, the crimper is pretty expensive. If your only doing a couple just crimp with pliers and finish solder them.
#24
my battery is back there so i just lengthened the original wire for the trigger to a 75 amp relay. grounded it right there and ran short 8 gauge wires from cutoff switch. one to each a1000
Mossyoakglock
08-28-2015 12:49 PM
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
