Gates Submersible Fuel Line
Old 11-28-2012, 05:53 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
This is the hose (from Gates) that I've been using for a couple years without any troubles. Is it the same stuff that you're having problems with? If there's something better out there that's available, I'd like to switch. Post it up!
Old 11-28-2012, 06:06 PM
tiffo60's Avatar
I ran this stuff in my lightning for the 4 years I had it and never had an issue
Old 11-28-2012, 06:15 PM
Baltimore Whore
Mangled03gmc's Avatar
I am using the same stuff, has been submerged for 4 years now.
Old 11-28-2012, 06:22 PM
MikeGyver's Avatar
Old 11-28-2012, 06:30 PM
MikeGyver's Avatar
I bought three of the same ones as the one that failed in the pic in the first post, for my future system. I hope the guy that I sold them to uses fuel that doesn't have the ingredient that ruined mine.
Old 11-28-2012, 06:34 PM
MikeGyver's Avatar
I guess I should stop putting mothballs, acetone, xylene, toluene, and 104+ octane booster in my tank.
Seriously, I only ever used Chicago-area, 93 octane, pump gas.
Old 11-28-2012, 06:40 PM
What are you running for a pump? Is it just the pic, or is the connector & wire getting cooked?
Originally Posted by MikeGyver
Old 11-28-2012, 06:44 PM
MikeGyver's Avatar
I'll o out and look later. I've had two stock pumps in this bucket. It might be burnt, or it might be a MikeGyver heat shrink job,
Old 11-28-2012, 06:56 PM
Old 11-29-2012, 05:27 PM
MikeGyver's Avatar
Yesterday I actually did think that I might have burnt the insulation putting on some heat shrink tubing. When I looked today, I remembered splicing in a short length of wire with a new tab terminal. This was to repair a burnt terminal. I guess I will crimp and solder it this time.
Good catch, thanks.
Quick Reply: Gates Submersible Fuel Line
