Holley hydro mat fuel socks/pickups?
Hey guys, What do you think about these fuel mats pickups for our trucks and boosted applications where fuel runs away from the pickup during hard acceleration? Seems it could eliminate the fuel starvation with low fuel levels and hard launches.
https://www.holley.com/products/fuel_systems/hydramat/
Just did twin 450 Walbro in a stock bucket, hence the stock venturi system went. Used a venturi pump from Radium Auto on the return line and used a piece of 3" x 15" Hydramat to feed the suction side of the venturi pump. Hydramat free floats on a piece of ptfe hose. Tried strapping it to the bucket but couldn't get it through the tank hole. I am able to read the stock fuel pressure in the return line and am only seeing 16psi of restriction versus 58 psi on the feed.
Looks like it would work well. A long skinny one toward the back of the tank I think would do wonders.
Radium Auto has a kit to attach in such a manner to a walbro pump. Question is how much the Hydramat would flow used strictly as a fuel pump pickup. Read somewhere the theory that too much suction would shut the capillary action on the hydramat. I used it strictly as a filter to feed the venturi pump and dump fuel into the bucket.
when i was researching these they were still pretty new but i found a guy that bought one and it couldnt flow enough for his turbo 350z or whatever it was. he even worked with holley on it and they couldnt give him any kind of flow numbers. he ended up getting rid of it.
