injectors size for a 6.0 600 rwhp?
60lbs. Depends on the base psi your calling it.
60@ 43.5psi
Or
60 @ 60psi
We have a flex fuel 6.2 dyno'd 610 with (stock Flex fuel injectirs)
54lbs I think is what they were called.
60@ 43.5psi
Or
60 @ 60psi
I don't feel that 60lb injectors are going to be enough to support 600rwhp without help from meth .
If that's your plan then get a set sized for your application that will let you achieve that power goal and give you some room .
I have 60#ers but without the meth I don't think they would have cut it .
Also mine are Deatchwerks plug and play. I suggest talking to them and seeing what they have for setup . I'd rather have plug and play then re-wiring /spacing if it can be avoided.
i have the same injectors as TIM Z
71# at 4bar
$450
Also my 6.2 flex fuel denali injectors are 36lbhr , what ones do you have ? Are they larger on the camaro or vette ?
E85 uses almost 2x the amount as gasoline.
I can not say whatvthe duty cycle was.
customer is in Florida.
He posted his build on here. Stock fuel system ls9 cam.
605hp @ 11-12psi.
605hp @ 11-12psi.
SD60's are fine for 600, they are actually 72's at 4 bar (58psi) I made 800 hp with them at the track, maxing out the 340lph fuel pump but was also running meth with a single 15gph nozzle. SD60's and a Walbro 450 would be my recommendation for 600 even with out meth.
so would these be good for 800 hp with some meth
Racetronix - LU108 - 80 lb/hr D4 High-Z Fuel Injector USCAR
Not to thread jack, but this is the issue I'm having. Last 2 months I can't seem to get my divers rear injector to seal. I'm running the siemens 80s with a ls1/ls6 fuel rail and its leaking like crazy were the injector meets the rail. I got the old style o-rings installed and just picked up a set of new style and some ls6 vette o-rings see if it will seal. Idk what else to do?
