Installing injectors
Old 10-01-2012, 07:31 PM
Chevy_King1500's Avatar
What did you add in order to have/buy 60lbr's just curious. With them I would not let it run too too long. It will def be rich, you don't want to wash a hole out.
trick turbo kit... i need to update my build thread lol
Old 10-01-2012, 07:57 PM
Slowest turbo build ever!
black00chev's Avatar
Ok so the injectors should be pretty straight forward. Im guessing just release the pressure at the schrader valve and get lots of towels ready for when I pull the rails off?
As far as driving goes... I hope it will be ok to drive almost an hour to get to where Justin is going to be tuning the next time he's in my town. I don't have a way of getting there otherwise. Or maybe Ill just wait until after he retunes my truck (trans stuff) to do the injectors.
hm...
Old 10-01-2012, 08:00 PM
GMCtrk's Avatar
It doesn't really drain that much when you release the fuel lines. Most of the fuel is contained in the rails and will leak out when you remove the injectors.
Old 10-01-2012, 09:55 PM
AndysC3's Avatar
I remove the fuel pump relay in the fuse box, start the truck and it will run for a few seconds then die once the fuel pressure bleeds out. Not as messy that way. And I used assembly lube to get the injectors in. Do not twist the injectors. That can damage the oring. Move from side to side until they are fully seated.
Old 10-01-2012, 10:37 PM
I forgot about pulling the pump relay. That should work a lot better. I usually do that when changing the fuel filter but its been awhile since I did my own.
MS3Z
07-30-2015 06:17 PM
Slammed96
07-27-2015 07:22 AM
lxcoupe
07-21-2015 02:12 AM
Quick Reply: Installing injectors
