Installing injectors
Ok so the injectors should be pretty straight forward. Im guessing just release the pressure at the schrader valve and get lots of towels ready for when I pull the rails off?
As far as driving goes... I hope it will be ok to drive almost an hour to get to where Justin is going to be tuning the next time he's in my town. I don't have a way of getting there otherwise. Or maybe Ill just wait until after he retunes my truck (trans stuff) to do the injectors.
hm...
hm...
I remove the fuel pump relay in the fuse box, start the truck and it will run for a few seconds then die once the fuel pressure bleeds out. Not as messy that way. And I used assembly lube to get the injectors in. Do not twist the injectors. That can damage the oring. Move from side to side until they are fully seated.
lxcoupe
07-21-2015 02:12 AM
