lonnies performance dual drop in pump 625$
IM looking for a dual pump set up for a boost build and ran across this. Lonnies performance has a dual pump kit that's drop in, hoobs switch, and harness for 625$. Has anyone ran this before?
Lonnies Performance Double pumper kits & Fuel Systems - GM Trucks
what wiring harnesses did you use to wire them up? i dont see a dual pump harness on racetronix website.
which walbro/racetronix harness did you use for your setup.?
im either thinking a single 450 or dual 255s.
The pumps were 128 each. The t fitting was 28 the hose was 30. 100' of 10ga wire was 30 Hobbs switch was 30. I already had the fpr which was 130. I made my own harness. Used the stock pump wire to trigger a relay which turns on one pump. The second pump is wired the same way but with the Hobbs switch wires in the ground for the relay. Turns on at 2 psi
