Mini Delphi to EV6 injector connectors wiring
Trying to make sure I wire new EV6 connectors correctly. Have found a few wiring diagrams for the truck harness I'm using, but trying to verify 12v and ground. Anybody have some insight as to what color wires are stock injector power and ground?
Harness is out of a 03-06 2500 3/4 ton
Found a van 6.0 wiring schematic
All the injectors should have a pink wire and another color(brown, black, tan, green, etc) the pink is 12v the other is signal from pcm, is all of your new connectors are red and black wire the red to the pink and black to the other wire on each injector, the pcm grounds the circuit to fire the injectors...
SvenLotus (04-12-2024)
Atomic
55
02-04-2021 01:49 PM
jasowole2cv
09-30-2020 07:53 PM
02Sierra2500hd
07-10-2018 08:34 PM
noproblems209
03-05-2016 06:28 AM
