New fuel pump assembly , walbro 255lph TU432HP . replace the fuel line?
Old 11-15-2015, 01:31 PM
zblee's Avatar
Originally Posted by DrX
I have read that the ribbed teflon hose is actually intended to smooth out the pulses in the flow.
edit: Found it in the service manual:
Fuel Pump
The fuel pump is mounted in the fuel sender assembly reservoir. The fuel pump is an electric high pressure pump. Fuel is pumped to the fuel rail at a specified flow and pressure. The fuel pump delivers a constant flow of fuel to the engine during low fuel conditions and aggressive vehicle maneuvers. The powertrain control module (PCM) controls the electric fuel pump operation through a fuel pump relay. The fuel pump flex pipe acts to dampen the fuel pulses and noise generated by the fuel pump.
thanks for this info. I ended up leaving the stock pipe on the assembly and tossed it in the tank.
melon07
20
11-28-2015 10:46 AM
marlboroman71818
11-09-2015 02:03 PM
bigsapper
11-09-2015 07:14 AM
greasemykey
11-06-2015 09:34 AM
Quick Reply: New fuel pump assembly , walbro 255lph TU432HP . replace the fuel line?
