Stock injector and fuel pump sizes for 99-02
I think the injectors are 24lbs? don't know the flow # for fuel pump.
Could one run boost with 24lbs like 2-4psi till money comes in for the fuel upgrade?
Slowest turbo build ever!
The guy doing my cam swap says they should be 24s. Only way to really tell is to have them flow tested. And like Kyle said, even 24s aren't enough for anything that turbo will do. Unless you run around without the wastgate spring in that is.
As for the stock fuel pump, they aren't great, that's for sure! They should have just installed the 255 pumps from the factory!
5.3lSilverado
25
08-29-2016 12:48 AM
Mossyoakglock
07-17-2015 08:30 AM
