stock injectors and fuel pump..will they be enough??
I think he marine are rated higher 42# (IIRC). I got a set of 39lbrs, that I will send off to get cleaned and serviced. I contacted Lonnie's performance to see about a drop in fuel pump. But then I seen somewhere someone had a surge tank hooked up so they did not have to go inside the tank and mess with the factory system.
The 8.1 truck injectors should be a direct plug in. You will have to have the truck tuned though. As for the marine injectors, they too should be a direct plug in, but I have no hands on experience with them so I am not 100% positive.
you may want to do some searching because i do remember seeing some where that the stock fuel pump is the same from a 4.8-5.3-8.1.. but do some looking on like summitracing or on any parts site
Interested on this also. My 6.0 with tune, lt's, and 217/223 .551/.551 cam is around110% on the injectors. My tuner suggested the new flex fuel injectors. I believe they are 36 lbs vs my stock low 20 lbs.
As I understand though is that the flex fuel injectors have a different plug. Would the 8.1 injectors be the better choice?
FormerVendor
I see it mentioned on this site often that 8.1 truck injectors are rated at 43 psi and need to be scaled up for the LS 58 psi rail pressure. I did just that when I installed my 8.1 injectors with hp tuners. It ran horrible! fuel trims were at 20%. I put the stock 8.1 data in the tune (30 lbs/hr and it then ran perfectly with 3% fuel trims. When you look up fuel pressure specs for a 8.1 truck, I find the same 58 psi as our LS 4.8, 5.3, 6.0's.
I feel like we should set the record straight about the 8.1 truck injectors. 8.1 trucks run with the same rail pressure as the LS engines. if that is true, when 8.1 injectors are used in the 6.0:s the injectors data does not need to be scaled up.
Someone please chime in if im wrong...
