stock injectors and fuel pump..will they be enough??
#22
FormerVendor
The 8.1 truck injectors are absolutely 1000% rated at 30 lb/hr at 4 bar (58 psi) not 3 bar. This can easily be seen by any of you guys with efi live or Hptuners, just pull up a stock tune file for a 3/4 ton truck with the 8.1 in it.
#23
ok so would it be better to go with the 8.1 injectors or the nnbs flex fuel injectors that I believe flow 36 lbs???? Don't wanna upgrade and it not be enough or upgrade and it be to much. This would be a for 6.0 217/223, LT's, and tune. What size are the stockers? 21?
