Walbro 450 pulse modulated capable?
Old 10-02-2013, 01:06 PM
  #51
lowyukon's Avatar
Hey GXPJAY, do you have the part # for the Flex Fuel pump? I wan to do the same as you.
Old 10-02-2013, 07:43 PM
  #52
GXPJAY's Avatar
Hmmmm, I was supposed to take a picture of it but I never did I looked on Car-Part.com for a fuel pump on a truck with Option "LC9" which is Flex Fuel.
And the little pressure valve only opens at ~78PSI on mine.
Old 10-02-2013, 08:48 PM
  #53
Byrdman11's Avatar
I looked at your pics more and yes the silver pressure release valve is in my sender too. Funny thing is I think I can blow threw my valve easy. Maybe I was to tried to check it right. I will be working on my setup tomorrow night. Still thinking about what to do to fill the bucket. Drill small hole, what size, etc.
Old 10-03-2013, 08:10 PM
  #54
Byrdman11's Avatar
Guys I install the walbro 450. I installed it in the bucket then tee off to the tube that the stock flex pump tee off to that fill the bucket. Work great so far. Idles on 42lb and 58lb when you switch the ignition on. Tuning soon and will post how the pump does .
Old 10-03-2013, 10:38 PM
  #55
GXPJAY's Avatar
Any pics?
Old 10-04-2013, 01:58 PM
  #56
ak2007r6's Avatar
Be awesome if this works as a direct replacement. Eager to see how FP holds up
Old 10-04-2013, 03:13 PM
  #57
Byrdman11's Avatar
Yes, its easy to replace it. And soon after I test the pump under full power. I'm install a inline filter. I have a video but cant get it to load up.
Old 10-25-2013, 03:47 PM
  #58
damianldaigle's Avatar
Results?
Old 10-25-2013, 05:38 PM
  #59
Byrdman11's Avatar
Sorry guys. Going to dyno this coming week.
Old 10-25-2013, 06:19 PM
  #60
How did you go about mounting it, didn't it not fit correctly
Quick Reply: Walbro 450 pulse modulated capable?
