What would it take to be able to run E85?
Old 09-19-2012, 07:58 PM
oakley6575's Avatar
Default What would it take to be able to run E85?
My truck didn't come with the flex fuel option. I'm wondering what it would take to safely run E85 when I wanted. Is there a way to add an ethanol sensor to the fuel system so the computer could correctly calculate fuel delivery? Thanks guys
Old 09-19-2012, 08:39 PM
TXSZ66AVLANCHE's Avatar
If your doing it to save money....don't bother.
Old 09-20-2012, 12:49 PM
oakley6575's Avatar
No, I wanna go fast!
Old 09-20-2012, 12:50 PM
nonnieselman's Avatar
for the 408?? your gonna need some big injectors
Old 09-20-2012, 01:04 PM
oakley6575's Avatar
Yes for the 408. I have 42lb injectors that are in the 70-75% duty cycle range with 91 octane.
Old 09-20-2012, 01:17 PM
GMCtrk's Avatar
Ive seen several posts on here that the stock fuel lines have no problems with e85. So im going to run big injectors with dual pumps and call it a day.
Old 09-20-2012, 02:13 PM
slammedsilvy's Avatar
Tune, injectors, and a pump.
Old 09-20-2012, 02:26 PM
oakley6575's Avatar
I'm looking to be able to fill at the pump and not have to "guess" what the stoich value is in the tune. I will only be able to use e85 every now and again. I'm guessing this is only possible with a newer PCM? or is there a way to add the ethanol sensor to the take and wire it to my 2003 PCM?
Old 09-20-2012, 08:32 PM
subscribed
Old 09-20-2012, 11:02 PM
oakley6575's Avatar
No one has done this im guessing..?
Quick Reply: What would it take to be able to run E85?
