00 2wd silverado pulling to the right...
Hey guys n gals,
So i asked about this on another truck forum and have had mixed responses...
Truck has near 100,000miles on it, original bearings still.
installed my hotchkis 2/4 drop in jthe summer and drove it as is until fall harvest was over with and had it alligned in november.
Didn't really notice it since it wasn't bad, but it pulls to the right like a sob. I let go and it seems to instantly aim for the ditch. I rotated my tires and the issue is still there. All tires are between 30-32lbs as well.
I've noticed lately a vibration, and that when i hit bumps the steering likes to jerk a shitton and seems feather light all the time, like theres no resistance. it wasn't like this when i had my power steering pump replaced so i ruled that out.
I've heard it could be the bearing or that the suspension just might be worn and knocking it back into a shitty allignment, or possibly my toe/camber is still off...im not sure about this one but do the nbs have the EVO thing like the obs had?
Anyone have this problem or if they heard of how it was fixed? Im goin to check the bearing assemblies tonight at my buddies garage for play since i finally got an assembly from napa just in case thats really the problem.
i think the early new body styles still have the evo's Not sure dont quote me.. I would check the front end.. If everythings tight get an alignment.. Caster split is probably way off..
GrooveCityZ71
08-31-2015 12:05 PM
85SS/85GN
07-22-2015 12:48 PM
2wd, adjustment, bearings, camber, driveline, nbs, problems, pulling, pulls, silverado, toe, troubleshoot, truck, vibrations, worn
