03-06 4WD Driveshaft?
Guys,
I have a vibration after my drop due to drive line angles. So far I see no real solution in getting them equal and less than 1* working angle.
Does anybody know if Chevy/GMC put 2 piece DS's in 03-06, 1500's, 4wd? Mine is a ~68" one piece aluminum. Considering swapping to a 2 piece that might allow me to adjust angles easier.
I wouldn't start the headach of compounding angles with a 2 piece shaft, keep it simple and work out the angle issues. Your drop is not radical so I can't see why shimming the pinion down a little (most likely) and possibly shimming the tranny/t-case up a little would fix you up. What are your angles now?
It's vibration free now until under torque and think its just the excessive working angle causing the vibration. I am hoping I can get there with a 2 piece.
I know chevyvho6000 (?) dropped 2" with shackles and never got rid of the vibration, he had a 2 piece to begin with. He relocated the carrier bearing and everything. I think thats why he got rid of his truck.... Hopefully he'll chime in and give you some info. He tried it all....
Going to try a couple different settings on the shackles, hangers, and shims over the next few days. Maybe something will click. If not I'll have to play with the driveshaft.
jscherbs
09-30-2015 07:54 AM
