03 6.0 wiring harness an ECm into 2000 Silverado
my 03 crew cab I think it's beyond fixing thanks to Sandy now that I want to know is can I take a drivetrain 6 liter and 4l 80 E and put it in my 2000 Silverado which had a 4.8 4l60 I would use the wiring harness drive by wire pedal everything can it be done?
TOTM: June 2007
Take your 6.0l and swap into the 2000. Run the 2000 intake and TB.
Its not worth the BS switching into DBW, when DBC works fantastic and already there. If you want a Bigger TB there are lots of options out there from nick williams, bbk, fast, oem etc. If you want a better flowing intake manifold go with a TBSS setup.
Few mods will need to be done to get the 80e to fit in, but all that info is on here and not hard to do
was trying to do this only investing my time besides getting the driveshaft shortened both trucks are down right now , the 4l60 is wasted in the 2000 was hoping to get one from our yard but we only 60's behind 4.3 and never got an answer if i could just switch Bellhousing and throw it in that would the quickest and easiest .
ARC
57
02-21-2022 10:54 AM
D1SCSS
01-25-2016 10:14 PM
mzoomora
01-03-2016 07:06 AM
Nimoryan
07-05-2015 03:50 PM
03, 2000, 2000silverado, 2007, 48, add, aftermarket, compatible, ecm, ecu, harness, market, silverado, wire, wiring
