04 Yukon Denali awd transfer case
Old 09-15-2011 | 01:59 PM
Yukon04's Avatar
Default 04 Yukon Denali awd transfer case
Just trying to get a idea at what kind of power the awd transfer cAse on my 04 Denali will handle and if there is any upgrades to make it stronger or replacements that are better?
Old 09-15-2011 | 04:45 PM
Bluchevypick's Avatar
I was making 10psi of boost on a 6.0 in my truck with the same transfer case and had no issues.
Old 09-15-2011 | 05:25 PM
zeake's Avatar
You should not have any problems other than normal stuff. I think that there is a sping update but several awd transfer cases have seen 1000hp.
Old 09-15-2011 | 07:33 PM
Yukon04's Avatar
Wow 1000 holy........
Old 09-15-2011 | 08:42 PM
zeake's Avatar
Yeah. 04chase is pushing 1k rocking an awd transfer case.
Old 09-15-2011 | 09:48 PM
budhayes3's Avatar
PT's Slowest Truck
There's an update for the clip that secures the pump as the original clip is prone to breaking and allowing the pump to rock around and eat through the magnesium case. There are also some aftermarket solutions that are more expensive alternatives to the $3 GM clip...I believe that Sonnax has one offering...
Old 09-15-2011 | 11:04 PM
1Bear's Avatar
You do have to remember that your dealing with a slightly different (actually a lot different) AWD transfer-case in an ’04 Yukon Denali than what is in the ‘01/’02 model YD’s, Sierra Denali’s, C³’s, ’02 Escalade’s and Silverado SS trucks. You have the BW-4481 instead of the preferred and stronger NVG-149. The BorgWarner is an open differential type that works in conjunction with the ABS to redistribute power to the axel that needs it, whereas the New Venture Gear case uses a viscous coupler to accomplish this task.
Old 09-16-2011 | 09:02 AM
budhayes3's Avatar
PT's Slowest Truck
Ohhhh, I didn't realize that it was a different t-case than the others...so the redesigned clip may not apply here?
Silver8ado
13
10-21-2024 10:09 AM
bluestang50
09-21-2015 09:36 AM
69z-28
09-21-2015 08:31 AM
Silver8ado
09-14-2015 07:35 PM
dselby25
09-11-2015 06:03 AM
