07 Nbs Sbrc 4/6 Djm Drop +
I lowered by 07 silverado with DJM's 4/6 drop. My question is, I used the flip kit in the rear but I want to lower another inch or two. It looks like I need a shorter shackle to lower it instead of a longer one, I suppose it's because of the flip kit. So any way does anybody know of someone that makes a raised shackle 1" or 2" prefirably?
Well it's seems like the action has been reversed if i put a lowering shackle (longer) it's going to push the leaf spring down, away from the frame, there for raising the back end. A shorter shackle (raising) will pull the leaf spring up toward the frame lowering the back end. Chime in anyone correct me if i'm wrong...
Originally Posted by RandomHero
A lowering shackle no matter how your leaf springs are setup is going to pull your suspension higher up into your frame. That in turn is going to lower your truck. A taller shackle is going to lower it while a lift shackle will raise it. As your axle goes up, the lowered affect increases
Did I install it wrong then? Cause that's djm's kit for the 07 nbs. Or did you not install the rear shackle mounts? You didn't do the flip kit, did you?
