08 silverado odd oil pressure issue
Just purchased a 2008 Silverado 5.3.
this is probably the 20th 99+ gm v8 I've owned, and I've done work on several more but this one seems strange to me.
truck had good pressure, then it randomly dropped to 0. turned the truck off for 30 seconds, restart it has 40psi for about 20-30 seconds then slowly drops to 0. Also dosnt fluctuat with throttle . Any ideas? Screen, sending unit, o ring?
It does have a lifter tick, but i dont believe that to be the complete culprit, or any thing to do with the pressure issue, no other nocks or any noise changes from 40psi to 0 psi
If it's a gen 3 set up it will be accurate to what the sending unit and the engine sees minus any loss from the oil filter.
First change the oil with a good filter, just helped chase down a similar issue and the filter o-ring blew out. Cheap filter failed and the simplest solution was the right fix after he dropped a grand at a dealer for "diagnostics". My 08 Tahoe started the lifter tick but just needed the correct weight oil and fresh filter after about 5k miles. Both were throwing codes for Oil Pressure Sender and his threw a code for something these trucks don't even have. Both fixed for a whopping total of $50 each.
Next verify true oil pressure or just change out the sender and clean the screen. You can move some stuff around and change the sender without pulling the manifold. Its annoying but can be done in a couple hours with the right set of tools.
Good luck
Good luck
Recap: new screen and sender fixed it kind of. It done it once more after the change (about 10 miles after) restarted the truck and hasnt done it since (200-300 miles) but now its throwing a code for the oil pressure switch along with service stabilatrac and traction control but gauge dosnt go below 20psi any more.
I had a similar issue to this, but it turned out to be not an issue with the sender or screen. I'll post up my own thread on it. Glad to hear you got it going though.
darkostoj
14
12-15-2012 05:31 PM
RotaryResurrection
87
01-23-2008 11:19 PM
