1/2 ton T case to 4l80E?
What is needed to mate up a 1/2 ton T case up to a 4l80e on my 2003. I know the input hub on the t case needs to be changed. But what adapter, and trans shaft do you use? And will the 4l80e witing harness plug in to the 1/2 ton truck? The 80 E is out of a 2002. Thanks, J
High on diesel fumes
Check www.speed-eng.com for a complete list of 4L80E conversion parts. Many people on the forum here (including myself) have done the 80E swap.
If you swap input gears on the t-case you can use the standard output shaft on the 80E. There's an adapter that goes between the 80E and the t-case to allow them to physically bolt together. If your 80E doesn't come with one, you should be able to find one at a hard parts store. I had to go to a Tru-Best Hard Parts here in Phoenix to find one.
The 1/2 ton harness will plug in, but you need to get a harness for a second VSS and there's an adapter for the big round green plug since the pinouts are different.
Superman09
09-25-2015 05:55 AM
LARRY01Z28
09-16-2015 10:02 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
FlowmasterMufflers
08-31-2015 05:11 PM
FlowmasterMufflers
08-28-2015 10:58 AM
