1 blown G80!!
#52
LS1Tech Sponsor
i don't think it was too much low end torque. the 10.5 is damn strong even with a G80. a quick killer of any differential is wheel hop. wheel hop will take out just about any gear type diff (non spool). the stockers such as a g80 will just go quicker. with his caltrac's on there this may not have happened.
#53
#54
Originally Posted by moregrip
not that it means anything
the timeslip says
r/t .4
60' 2.6
1/8 11.2
mph 70
1/4 16.6
mph 92
the timeslip says
r/t .4
60' 2.6
1/8 11.2
mph 70
1/4 16.6
mph 92
#55
14 Second Truck Club
Thanks for the info!
looks like the open carrier is about $200 bucks and the locker is about $400 bucks. That's $600 plus install,
Can I do this myself? I really prefer to do all my own work
Maybe not as easy as it sounds, but you should be able to handle it. You will need a dial indicator and magnetic base. Check your backlash before disassebly, and reset it the same.
#58
the eaton is the most common because many feel the detroit locker to be excessive. to me it's just right.
as for your diff there grip, i'd see if the dealer will warrenty it for you. i know where i work it wouldn't be an issue. that's the same that comes in the 8.1 suv's and it should take the power. if you can get them to do it you can either sell the locker they replace it with or if you are really in good with them they will put an open diff back in it's place. either way i'd try warrenty first to try to knock down some of the cost.
#60
It has never been touched, truck has 6,800 miles on it
I guess it could be a defect?
