10.5 or 9.5" Converter
PT's Slowest Truck
So now I'm thinking of going with either a PI Vig single disc or a Circle D stage I, something in the 2800-3200 range, but I'm trying to figure out if I should go with a 10.5 or 9.5 verter. I don't plan to tow so I don't need the extra size of the 10, but I like that it won't generate as much heat since this is my DD. On the other hand, the 9.5 will be lighter and have less rotating mass, but run warmer. Any other pros/cons of each? What do think I should chose?
I think the 9.5" acts "looser" than the same stall in a larger converter. I had a 9.5 3300 when I had the 60 in and it was a pain in the city, especially hills. Really roasted the tires though!
I got an Edge 9 1/2 single disk for my 80e swap. He speced it for me and my setup and built it for that. Said I would be fine to tow with it since it's a much more efficient converter then the bigger converters. Also told me it wouldn't be a problem to lock up the clutch at WOT at all. His spec was a 3000 stall with a 2.40STR. He said it won't be a "loose" feeling stall on the street at all and you could deliver news papers with it if you wanted to, lol. Might give Andre a call.
I am more than happy with a 10" 3000 in the new 80 but thats a whole nuther story.
