10 bolt trouble.. AGAIN
It looks like my 10 bolt has went out yet again. I think the pinion seal went out and it puked oil all over. A few minutes later, a loud howl. Pulled over and seen the oil all over the bottom of the truck. Refilled and the loud noise was still there. It is such a mess under my truck!
Im sure its going to need new gears, bearings, and the eaton rebuild kit, I wonder if I should consider the 14 bolt 9.5" rear end and drum brake set up.
I looked on car-part, and the situation doesnt look good. Not any there. Does anyone have recomendations? I seen others post on that it will cost over $2500 for the 14 bolt, a bit steep IMO.
Can any other model years work with some relocating of the spring perches and drilling hubs for a 6 bolt pattern.
Please help!
Please help!
10 Second Truck Club
Would the "new" 14bolt be a direct bolt in basically then? Do the "new" 14 bolts have drums?
iregret
09-07-2015 01:20 PM
