10 bolt vs. 14 bolt
Old 07-27-2010, 02:41 PM
walledition's Avatar
Default 10 bolt vs. 14 bolt
My truck stock came with a 10 bolt spicer 3.73 non posi, since i wanted 4.10´s and posi i went to the junk yard and got a 14 bolt posi with stock 4.10´s, never opened, it was a lot havier, my question is: does the 14 bolt make me a lot slower? i know it should be stronger
Old 07-27-2010, 02:43 PM
Baltimore Whore
Mangled03gmc's Avatar
Will it make you slower?? Hmmm maybe a bit. Just do to the fact it is alot more gear to spin, as far as weight goes, more in total weight.. My ?? is what kinda power do you put out, what kinda power do you plan to make?? If it is under 700 to the wheels I think a good section and gears along with a girdle would be more then enough..
Old 07-27-2010, 03:43 PM
5 year bitches!
Quik's Avatar
curious as how you found a 14 bolt with 410s unless your meant a 8 lug. Or a TBSS 14 bolt
Old 07-27-2010, 03:59 PM
Baltimore Whore
Didn't the 2wd silvy SS trucks have 14 bolts in them??
Old 07-27-2010, 04:07 PM
Coban's Avatar
Think they only had 3.73
Old 07-27-2010, 04:10 PM
11 Second Truck Club
MPFD's Avatar
Is a Girdle really needed? How much strength will it add?
Old 07-27-2010, 04:14 PM
i have no idea where it came from, i only found written 4x4 on it so i know they took it from a 4x4 and the gearing they had a way to find out what gears it had in by turning it around, and well speedometer show more then it really is driving, that i checked with the gps, that's all i know
Old 07-27-2010, 04:20 PM
u think i should have stayed 10 bolt with some good stuff in it and call it a day?
Old 07-27-2010, 04:23 PM
MPFD's Avatar
I do...
Old 07-27-2010, 04:26 PM
Baltimore Whore
Yes I honestly do. It is kinda a pita to do the swap( not hard but ) A ton of guys are going deep 10's on a built 10 bolt.. The axles are plenty strong. It is the center sections that take a ****.. Like I said before. A good center section, good gears, a girdle will allow you to put a good bit of HP through that stock rear. JMO
Quick Reply: 10 bolt vs. 14 bolt
