10 bolt vs. 14 bolt
Old 07-27-2010, 04:29 PM
EVILGMC's Avatar
i am still running a ten bolt....girdle, eaton posi, fresh gears. no issues and more than a little bit of hp/tq
Old 07-27-2010, 04:35 PM
The House is Rockin'
BLUES MAN's Avatar
Originally Posted by Coban
Think they only had 3.73
nope they came with a 4:10 gear.
Old 07-27-2010, 05:01 PM
5 year bitches!
Quik's Avatar
2wd SSS rear is a 373 gear 14bolt
Old 07-27-2010, 05:16 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
AWD SSS and Sierra Denali AWD ran 4:10 gears standard. Never have seen a 2WD SSS in this state.
Old 07-27-2010, 05:34 PM
5 year bitches!
Quik's Avatar
awd sss had 10bolts with 410s
2wd sss had 14bolts with 373s
also sierra denali didnt use a 14 bolt, more long the lines of a dana for the quadsteer option
Old 07-27-2010, 06:02 PM
james8997's Avatar
my ten bolt was 260 pounds IIRC
my 14 bolt is like 390, but 70 of that is in the HUGE drums, so if you do a disk break conversion, your lookin at 330 pounds, only 70 pounds more than a 10 bolt with drum breaks, but ALOT stronger, thats just my opinion, i wanted a rear axle i know could take a beating
HomerSimpson (09-09-2022)
Old 07-27-2010, 06:11 PM
5 year bitches!
Quik's Avatar
14 bolt from silverado uses g80 14 bolt from tbss has g86
Old 07-28-2010, 12:48 AM
Also, to make things even more confusing, not all Sierra Denali's were quadrasteer.
You're all over this Quik!
Old 07-28-2010, 04:57 PM
1Bear's Avatar
It's not too badly confusing:
'01 Sierra C3 = 10 Bolt
'02 - '04 Sierra Denali = Dana 60 Quadrasteer
'05 - '07 Classic Sierra Denali = 10 Bolt
'07 to current - Sierra Denali AWD = 10 Bolt
'07 to current - Sierra Denali 2WD = 14 Bolt
Old 07-28-2010, 05:33 PM
I have a gauge for that
Atomic's Avatar
the 14b is much, much stronger than the 10b. i put in a 14b because even though there are guys with 10bs running tons of power, i am heavier than most at 6000+ and have 35" tires, which really take a toll on the rear end.
Quick Reply: 10 bolt vs. 14 bolt
