1000 Hp Rear end.
Originally Posted by zippy
you can get the same 9.5" rear from a 2005 or newer 1/2 ton with an LQ9 and 2wd. from there just put a detroit locker in and you should be fine.
All the LQ9 (345HP 6.0) AWD combinations I have seen use a 8.6" 10-bolt in the rear.
I am not sure if the VHO would be a 9.5". If it is than that means it would be a 6-lug configuration. 6-lug 9.5" in drums are easy to find, as are 8-lug 9.5" rears with discs. It's the 6-lug with discs that is going to be difficult.
The new Vortec Max "Performance Pack" trucks have LQ9's, 4L70's, 9.5" ring gears and some seriously big *** drums in the rear. The Vortec Max "Performance Edition" trucks are the same except with a 4L65E instead of the 4L70E.
