14 bolt in a 00 Regular cab short bed????
Formerly Low_LQ4 - 6/6/10
I have a disked 10 bolt rear end and trying to jump to the 14 bolt. Has anyone done this swap to their Regular cab truck with disk brakes in the rear. If you have done this could you please let me know what is needed. Thanks
If the 14bolt came with drums, it will clock your calipers 45* clockwise on the driverside adn 45* counterclockwise on the passanger side, and you will either have to get an HD u-joint for your drive shaft or reuse the stock pinninon flange to connect to the driveshaft. Other than it is a staight forward swap.
Thanks guys. I found what is needed. 2006 Chevy Silverado 1500
3.73 ratio (opt GT4), w/hybrid axle (opt AXN) 14 bolt
Shtbox
08-02-2015 10:52 PM
