14 Bolt Swap Complete - Pics Inside
#61
Update, the 14 bolt out of a nnbs works in the nbs trucks also, I did this and everything bolted up, the only thing I did was put my backing plates off the 10 bolt onto the 14 bolt since my wheels wouldn't fit the nnbs disc setup and since I had done the suv upgrade previously
#64
In today's lingo that is correct, however for us that has been through several body changes, it does tend to get a little confusing. In my case from the '60's on, the new body style doesn't mean a lot anymore, and instead is just easier referring to them by their official designation, such as GMT-400, GMT-800 and/or GMT-900. I'm sure there are quite a few more members that have been through a couple of more body styles than I have and are setting back and thinking which new body style!
#65
I'm tempted to look into getting a fabricated rear end just for the cool factor. I know that the 14 bolt would be a lot cheaper but the fabricated housings are just very cool. The one factor that keeps me from moving ahead with the fabricated rear is that I have a hand built 24 gallon fuel cell under the rear of the bed and the fabricated rear housing wouldn't show. I don't think a person could see the fabricated rear unless they crawled clear under the truck.... but I still want it
#66
I have Centerline 20's and 14" rotors on mine so do you think it would all bolt up?
What is the suv upgrade?
#67
There again, the “SUV upgrade” is just a common terminology that people have adopted for the dual rear piston caliper, larger/thicker rear brake rotors that were common to the SUV’s and are being swapped to the trucks with lesser units. What is a misnomer is that they were just used on the SUV’s, as the Sierra C³, Sierra Denali, Escalade EXT, SS trucks, ECT. also used the same components.
#69
the 14 bolt i got for my truck was out of a 08 silverado vortec max, at first i was worried because the shock mounts are different on the 07+ trucks, but theres enough play in the shock bushings to bolt them up, and also it already had disc brakes on it but since i only have 16inch wheels they wouldnt clear so thats why i transferred my original brake setup over, so if you have 17inch wheels or larger no need to remove the o.e. brakes....
#70
Custm2500's Rude Friend
https://www.performancetrucks.net/fo...thread-467473/
All the info you can handle on the 14 bolt 9.5 SF
