14 bolts
5 year bitches!
14 bolts
now i know the SSS has them in the 2wd models now do the VHO have a 14bolt as well? and if so do all models have them?
can you get a 14bolt with disks or is it only drums, im in need of a rear
You can pull the axles and swap the backing plate a rear disc backing plate.
The bolt up procedure is the same as the 99-04' model GM trucks.
You can swap over the disc hardware onto your 14 bolt axle.
Baer Brakes makes a rear disc conversion kit for the 05' & up 1/2 ton trucks that have the rear drum brakes.
If you look at the hardware kit, you will see that is a lot of factory components to do the conversion.
The kit is about $1200.
I guess there are a few different ways to do this conversion, but it can be done without getting rid of your rear axle.
Jim
Jim
iregret
09-07-2015 01:20 PM
