15 inch drag radials
Old 06-04-2006, 09:35 PM
Banned
litreddevil's Avatar
m/t also makes a 16x 26x10.5 and they were good enough for a 1.64 60 with the 5.3at a 12.59 so i think they work
Old 06-04-2006, 09:58 PM
9 Second Club
Rhino79's Avatar
Originally Posted by speedy02
Do you have a picture of the grinded caliper's and of the wheels mounted on the truck? I want to run the M/T drag radials but they only make one size for 16" wheels 255/50r16. That's the size i run at the track.. I want to run the M/T 275/60r15 DR's..
I'll try to get a picture up tomorrow for you, but the race wheels are not here so I can't get a pic with them on, they are about an hour away, but I will take a pic of the caliper with the wheel off. I can tell you that I just ground enough to clear, which envolved me trying and re-trying until there was no rub. I used a 4" angle grinder and then lightly finished them with a dremel style polisher.
Old 06-04-2006, 10:07 PM
5 year bitches!
Quik's Avatar
i did the same as you did but after i did mine realize i didnt care to do it. so i just tossed the modded caliber. the rim i tested was an old steel wheel that was stock from back in the day which arent bad and they can use the stock 16" steel center cap
Old 06-04-2006, 10:08 PM
9 Second Club
Rhino79's Avatar
Here is a pic from the last night they where run back in the winter, you can't see the caliper but I will get a better pic up hopefully tomorrow. You can at least see the style wheel I used. Tire size is 28x11.5 on a 15 x 8 rim.
Old 06-05-2006, 01:44 PM
9 Second Club
Rhino79's Avatar
Well no going to be able to get a pic today, but here is what I went off of:
https://www.performancetrucks.net/fo...d.php?t=348092
Old 06-05-2006, 02:22 PM
Hunt&Fisherator
silver-mod-o's Avatar
I'd be kind of nervous doing this because of possible weakening the body of the caliper.... I dont know...
Old 06-08-2006, 02:46 PM
joshluther's Avatar
I only took about an 1/8" off. I 've been running them like this since last September with no problems
Old 06-08-2006, 03:20 PM
quicksilverado's Avatar
Plenty of people been doing this for years on the f-bodies with no issues. I did mineabout 8 months ago.
Old 06-08-2006, 06:47 PM
11 Second Truck Club
Breeze's Avatar
Joshluther what is the backspace on you're 15'' rims? and what is max backspace do you think we can get on our trucks. Thanks.
Old 06-08-2006, 08:58 PM
5 year bitches!
Quik's Avatar
well i got fucked so im stuck with 15s for this weekend. minor error so ill be mounting aset of old Rally wheels with 28x11.50R15 et streets on a 8" rim ill get pics to help out
Quick Reply: 15 inch drag radials
