16" Bogarts finally on
#32
Front 5x16 = 11lbs
Rear 10x16 = 15lbs
No contact anywhere except the rear banjo bolt. I just did minor grind on bolt head and turned it away from the rim a few degrees and all was good.
#34
If I can get a brake caliper issue sorted out on my truck this week I may try to make a day trip since they are running on Saturday afternoon.
#35
Must be running S10 calipers then to clear the banjo bolt. *EDIT* Never mind, just read your last post where you clearanced the bolt.
#36
I drew out a diagram of each disk with every demintion I could measure. Give me your email and I will send you the pdf.
Front 5x16 = 11lbs
Rear 10x16 = 15lbs
Front 5x16 = 11lbs
Rear 10x16 = 15lbs
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
