1994 rearend in a 99+ silverado?
Restricted User
unless you want to spend money on a down grade then dont do it.... the carrier bearings are smaller on the inside... the spring perches are about 1.5 inches wider on your truck also...
I put a 12 bolt from a 94 4x4 under my 2000 single cab. We shortened it 1in on each end, put mosier axles and a eaton unit in it. The spring perches do have to be rewelded. The drum brakes were easy to hook up and we then could easily fit a 15" rim on back and tuk some meat under the rear fender wells without minitubbing it.
sprayedenali
17
08-07-2015 08:15 AM
Offroadunleashed
07-20-2015 02:25 PM
