1st gear grinding.... 4l60e
Bringing this one back from the dead. I've got the grinding in 1ts and 4th, symptomatic of a 1st and 4th thrust bearing? Trying to get an idea before I start loosening bolts.
You say grinding. Like it will not go into gear? If not and it sounds like a rough noise as you drive and is quiet when you shift into 2nd you most likely lost a 1st gear thrust bearing.
Park it and fix it. It will not go away or stabilize. It will keep getting worse and leave you on the side of the road. I know this by personal experience.
MileHighSierra
07-12-2015 12:23 AM
