2-3 shift slip
Old 03-28-2011, 05:28 PM
11 sec. Truck Mod
TIM Z's Avatar
I found the fix for my prob too, 80E !!
Blew 3-4 out yesterday. my 4th 60e in 1000 miles.
Dont use Alto clutches in the 60e, Stick with Borg warner .
Old 03-29-2011, 03:57 AM
swampthing's Avatar
This truck doesn't warrant a 4L80E - it's essentially stock, but I'll try the Vette servo and see if it helps.
I found that this slips a lot more when it's warm. Right after start when the trans is in warm-up mode and holding gears a little longer, it shifts about how it should normally.
Which servo should I replace?
Old 03-29-2011, 10:01 AM
BLACKND's Avatar
Originally Posted by Beatdown Z
My mom's 03 Trailblazer with a 4L60E had a 2-3 slip/flare, so I swapped in a Corvette servo and now it shifts perfect(even after 30k miles). I later found out that a 2-3 slip/flare can be caused by damaged servo seals. So switching to a Corvette servo will give you firmer shifts and potentially fix your 2-3 shift issues. Win win.
This is what my mechanic essentially told me too. I want to have him do the servo and go back with a transgo hardened seperator plate and do a flush and filter and see how it is.
Old 05-04-2011, 04:44 AM
swampthing's Avatar
Solved! Turns out it was the PCM. I swapped my stock PCM back into the truck and it shifts fine now. I don't know why or how it was causing the poor shifting, but it is working how it should now.
Old 05-04-2011, 07:55 PM
05gmcsierra's Avatar
well i guess will c how much those red eagle alto clutches hold.. i installed them on my truck.. been doing good for 5 months now and she gets a good beating lol..
Old 05-05-2011, 06:39 PM
5.3 GMC's Avatar
I have had red eagle clutches in mine for 8 months now. It's finally started to slip some. But it gets rode hard and put up wet most of the time. But certain people have better luck with some brands than other people do.
Old 05-12-2011, 12:36 PM
Banned
1990LSx's Avatar
I couldn't tell you how many 60Es I been through. We tried everything in the tune with no luck. In the end the 80E will be the best choice if your making decent horsepower.
Old 05-12-2011, 01:24 PM
nonnieselman's Avatar
I think i went thru about 17 haha..
But even now with no boost and a stock LQ4, the 80E still is a nice touch.
Old 05-12-2011, 03:17 PM
11 sec. Truck Mod
TIM Z's Avatar
You guys might be OK with those clutches if your Not FI.
Damn 17!! ???
Wow thats expensive, i thought the 4 that i went thru was bad enough! I feel really sorry for you, or maybe not. You should have went 80e wayyyyyyy sooner! LOL
Old 05-14-2011, 09:09 AM
Vince B's Avatar
Here is an article that you might want to read and see if it applies to your vehicle. http://www.sonnax.com/system/pdfs/13...pdf?1289926276
blownss27
08-14-2020 08:27 AM
drummer0415
11
10-24-2015 08:16 PM
Chevy305
09-28-2015 09:21 PM
iregret
09-07-2015 01:20 PM
mayko
09-07-2015 12:24 PM
Quick Reply: 2-3 shift slip
