2/4 drop on 20" rims
Old 04-27-2007 | 05:16 PM
shakesvho's Avatar
Default 2/4 drop on 20" rims
I have 275/55/20 stock rims is anyone running this type of rim/tire combo on a 2/4 drop, and if so any problems, did a search and could not find any info
thanks
Old 04-28-2007 | 02:56 PM
thunderwagen's Avatar
I am running a 2/3 drop on mine with 285/55/20's no problem. If you are using the McGaughys drop dont set the hangers on the lowest setting or you will be squatting in the rear. With them on the lower hole on the hanger and bottom hole on the shackle you will be level. If you want a slight rake then use the top hole on the shackle.
Old 04-28-2007 | 03:10 PM
shakesvho's Avatar
thanks for the reply, I'm going with the 4" leaf pack
Old 04-30-2007 | 05:48 PM
Nick99Chevy's Avatar
There's no way I could run 275/55's on my 2/4.
Old 04-30-2007 | 08:20 PM
shakesvho's Avatar
what do you have, and can you post up a picture
Old 04-30-2007 | 10:31 PM
275/45's on a McGaughy's 2/4. I'd rub if the tires were any taller.
Old 05-01-2007 | 01:11 PM
shakesvho's Avatar
that looks good, I may have to go 2/3 or change tires to get the 2/4
Old 05-01-2007 | 02:20 PM
The VHO's sit differently than a regular Silverado. If you go with a 4" drop in the rear It will sit lower in the back than in the front. I ran into that when I first lowered mine and put the hangers on the top hole. You may be able to crank the torison bars to get it level, but your ride will suffer.
Old 05-01-2007 | 02:30 PM
shakesvho's Avatar
Its looking more of a 2/3 drop, did you have to add shines and a carrier bearing and hows this ride
I have the 4" leaf packs order will try to cancel
Old 05-01-2007 | 02:43 PM
JonD985's Avatar
shakes i would go with the 2/3 that's the drop i'm getting
Quick Reply: 2/4 drop on 20" rims
