2/4 drop...rouph ride
Old 08-04-2008, 09:24 AM
ecmoney's Avatar
Default 2/4 drop...rouph ride
I did the 2/4 drop and it looks nice but my only complaint is how rouph it rides in the back. I have shackles and hangers with stock shocks. If i change out the shocks do you guys think it will ride better?
Old 08-04-2008, 09:33 AM
95 bright teal's Avatar
did you change your bump stops or cut them down?
Old 08-04-2008, 09:36 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
The stock shocks are riding on their stops no doubt and you are getting no downward articulation. Change the shocks, you need 4" drop shocks, and yes the bump stops will need to be shortened.
Old 08-04-2008, 09:45 AM
ecmoney's Avatar
yes i already shortened them, and i have the shocks just havnt installed them yet. so I guess there is my answer. thanks
Old 08-04-2008, 09:54 AM
also think about a cnotch, some with 2-4 need it some dont
Old 08-04-2008, 10:36 AM
Stoichiometric's Avatar
With a 4" drop and a notch you can retain as much travel as factory. I would recommend the notch, especially if you use the truck for heavy loads.
Old 08-04-2008, 11:04 AM
carfreak07's Avatar
I just done a 2/4 and removed my bump stops, still rides the same! I dont have a reese hitch or spare tire on the rear though, you may have some additional weight than I do. I do have the factory chrome bumper! My ride is a 2000 rcsb 2wd
Old 08-04-2008, 11:41 AM
ecmoney's Avatar
I dont have a spare, but i do have a hitch. the only thing i put in the back is a couple of dirt bikes, how difficult is it to do the c-notch. just some cutting and welding i suppose huh?..actually could you guys show me some pics of yours please.
Old 08-05-2008, 08:12 AM
barley's Avatar
personally i would not go to the trouble to c notch your frame if 4" is as low as you want to go. Get your self some good shocks seriously buy good shocks and maybe cut a little more off your bump stops
Old 08-05-2008, 08:29 AM
lady3bglover's Avatar
Just put the new shocks in, you should tell a diff. I have the Belltech 2/4 drop kit w/the Nitro 2 shocks and alignment kit too.
Quick Reply: 2/4 drop...rouph ride
