2 built tranny's in a 3 month
Old 08-06-2008, 11:53 AM
charcold-bowtie's Avatar
Default 2 built tranny's in a 3 month
Im having hell with the 60e's. I had one built and a TC refreshened. After getting it installed, and around 5000 miles, the converter came apart and screwed the whole tranny. Got it taken care of, different converter company, same builder. I then installed that trans on july 4th. Last night it came apart as well. I lost drive, manual 3rd and 4th. I have manual first and second gear and reverse. 2 questions.
Any guess to what gave on this one. Input sprag?
Has anyone heard or know of what the hell could be causing this. Like excessive crank play or anything......
The second trans had maybe 2000 miles, no track passes, no tuning. Sure ive gotten into it some, but mainly driving 50 miles to school and back everyday.
thanks for any input. Im thinking 80e im sick of this ****.
Old 08-06-2008, 11:56 AM
Moddoo's Avatar
pieces of parts in your cooler or lines??
Old 08-06-2008, 11:59 AM
On the 4th trans swap, i put all new AN lines from the trans forward with a tru cool cooler (new). And i bleed some fluid out the lines to ensure they were good when I got the trans in.
Old 08-06-2008, 01:12 PM
LS1TECH & Trucks Sponsor
performabuilt's Avatar
You could have broken the input sprag but I am betting on the low roller clutch and suggest you check out your rear end and if 4x4 your transfer case. I don't know what happened to your other units but I have seen either of these take out the low roller in a trans a couple times before someone figured out what was going on .
Old 08-06-2008, 03:57 PM
I had 4.10 gears and a eaton unit installed apprx 35,000 miles ago. Hmm, Check driveline angles and such maybe??
Old 08-06-2008, 04:08 PM
Resident Retard
BlackGMC's Avatar
Your truck just hates you!!! That is why you keep breaking crap....
J/K, hopefully you get it fixed this time... If you go 80E, with you gears your going to be turning some serious RPM going down the highway....
Old 08-06-2008, 04:20 PM
Baltimore Whore
Mangled03gmc's Avatar
What brand verter, trans are you using.. I know it sucks.
John
Old 08-06-2008, 04:44 PM
local built trans its built by a VERY reputable builder around here. I have been completely unimpressed. I dont know the brand of converter, 2400 stall. From a company he has been using for a while. The first converter that let go was a rebuilt PTC. Im really thinking and 80e swap from a sponser.....
Old 08-06-2008, 05:16 PM
Baltimore Whore
Thats what I would rec, granted you are make power with a turbo 4.8, but shouldn't be shreading tranys like that.
John
Old 08-06-2008, 05:27 PM
11 Second Truck Club
Breeze's Avatar
Do the 80e swap you wont regret it contact Performabuilt.
Quick Reply: 2 built tranny's in a 3 month
