2 New sets of gears = Annoying!!
The 4.56's were used, the 4.88's are brand spankin new. I may order another new set from moser and have them do their lightening service if i cant get them to quiet down some. After all the christmas stuff this weekend im goin to tear it all back apart, hell the oils drained and cover is off already.
just installed a set of MOTIVE 410's in my 14 bolt sunday and no whine here either! my backlash is .005, they do tend to loosen up a slight touch from what ive seen.. i do have a super small whine slowing down also but all the nnbs trucks do if you listen close.. its not the gears its the tranny im pretty sure, did it before my gears so idk lol....
the richmonds in my firehawk whined from day 1. i was told its just how they are, cut for durability not for NVH like the factory gears. never bothered me though my tolerance for noise is pretty high when it's performance associated
Did you use a pinion shim other then the stock pinion shim? From what I've found and what they told us at school is the pinion shim makes up for the differences in machining of the axle housing to help locate the pinion correctly. For the most part the ring and pinions are made pretty true. That being said I've gone from 3.08s to 3.73s in my 95 and played around with the pinion shim for way too long before I threw the stocker in there and wouldn't you know it was perfect. I've also replaced a handful of worn out ring and pinions with stock parts and the stock pinion shim has always been ideal in that instance too. For what its worth I bought my 3.73s used, had just under 100k miles on them and came out of a lifted truck. Gears looked great and for 55 shipped I couldn't go wrong. Threw them in, set them up a little tight, something like .004-.005 backlash but they worked perfect. Dead silent, smooth, perfect.
pinion was shimed to with whatever it took to get to the 2.513, i dont remmeber if it was stock or not, but i dont think it was and looking at the wear pattern its too deep meaning i need to shim out some more. Im goin to recheck everything this weekend after all the christmas stuff.
