20" Rear Wheel backspacing question??
Formerly Low_LQ4 - 6/6/10
What is the max backspacing you could run on the stock rear of a 2000 GMC Sierra?
I'm trying to get some 20x11 wheels, and run some Nitto's 555R 305/35/20DR in the rear. Thanks for the help.
backspacing is not as simple as it seems as other factor will be the section width of the tire you are intending to use on a particular width rim. a 7.5 bs might work with one tire but not a wider section width one. something to consider. 7 bs would be a safer bet but i would only widen rim to perhaps minimum rim recommended rim width of tire you want to use to better my chances of all fitting and not rubbing on inside leaf. good luck and keep us posted. Rob.
BoostedBowTie
01-03-2020 06:46 PM
mrgrim
07-08-2015 08:12 AM
