2000 4WD Transmission removal... what's the trick?
Old 11-19-2015, 09:05 AM
  #21
I have a gauge for that
Atomic's Avatar
That's only the fancy automatic case, the manual shift and non-auto 4wd case use trans fluid.
Old 11-19-2015, 09:20 AM
  #22
tgui's Avatar
Ahhh ok. I had no idea.
I have to use smurf blood in my fancy auto case.
Old 11-19-2015, 09:23 AM
  #23
Choda's Avatar
You can use a small flathead screwdriver to remove the cooler line E clips relatively easily. Just find the edge of one and push and it will roll off.
YES! these are not the same fittings that most fuel lines use. There is a little spring clip you have to PICK out of the plastic fitting.
I still dont see a 2 foot 3/8 extension. Go get one. thats how you get to that top bolt and it makes putting the other bolts in a lot easier.
Make sure you remember where the bell housing bolts/studs go. Some were different lengths with mine and caused me to futz with it a while before I found it.
Old 11-19-2015, 09:32 AM
  #24
Atomic's Avatar
If you want to practice with the E clips the fittings on the radiator for the trans are the exact same...
Old 11-19-2015, 09:59 AM
  #25
harner's Avatar
A screwdriver on the line at the trans sounds easy and all, but where the trans sits right now, there's no way. I tried for a while to sneak in there with all different size screwdrivers that have very thin and narrow blades. They are corroded and pretty nasty.
I did see they are the same at the rad side. I had a '98 Grand Prix that had the same setup and a pick was easy enough to remove the cllp. I'll try them with a pick first, if that doesn't work, the special tool will do the trick.
I have a long extension on standby, I think it's about 3' long. Just need to drop the xfer case so I can see the bolt since my tree-trunk fingers can't get to it by feel.
Smurf blood LOL.
Love the responses here! Thank you all so much.
Old 11-19-2015, 11:56 AM
  #26
Wolftrk99's Avatar
A small pick with either a curve or a 90 work better than a screwdriver on the trans line clips....
Old 11-21-2015, 08:06 AM
  #27
harner's Avatar
Got the trans out! Used a pick on the E clips and the cooler lines popped out. Trans broke free with some pry bars and light tapping of a hammer. Dowels are nasty.
Off to the trans builder it goes. I'll update the thread from there.
For anyone interested in a pro builder whose trademark is making 4L60e's hold up to big power and not break the bank, here ya go:
http://cpt.pszweb.com
This will only be a stock rebuild but I have his Pro Race in my T/A and its a work of art.
Old 11-21-2015, 08:31 AM
  #28
Wolftrk99's Avatar
Id be interested to know which 5 pinion planetaries hes using for $100 a piece.....
Old 11-22-2015, 09:13 PM
  #29
harner's Avatar
Shoot him an email or call. Contact info is on the site.
Old 11-22-2015, 10:48 PM
  #30
tgui's Avatar
He's alluding to the influx of cheap Chinese 5 pinion planetaries know to be problematic. The real GM ones are quite a bit more $$, and worth it.
I am not a pro, and this is only what I've read.
Quick Reply: 2000 4WD Transmission removal... what's the trick?
