2000 silverado single cab 4l60E to 4l80E question 4x4 to 2wd
Old 04-23-2021 | 01:19 PM
vergesilverado's Avatar
Originally Posted by arthursc2
We can tell because the pics you posted tell us what we need to know:
there is a flange with the 6 bolt holes: t case bolts there
-and-
there is no cone with a slip yoke seal on the back
Thanks for the info im gonna check again to see if the cup is there inside the output side for the fluid also i have the tail housing for it, its just not in the picture and bolts up as it should.
Old 04-23-2021 | 05:29 PM
-and-
Old 04-23-2021 | 06:25 PM
arthursc2's Avatar
What are you showing? All transmissions have an output shaft seal, even 4wd ones
2wd ones have an additional seal. One that seals to the slip yoke, and is pressed into a cast piece called a "tail housing" that is shaped like a cone
you have a 4wd trans man. Sorry to say
Old 04-24-2021 | 03:29 AM
I understand what the tail housing is its not on the trans in those pics but i do have it off to the side and i mentioned that above, Do you have pictures of what your talking about like I said there wasn't much info on how to identify the 2wd and 4wd trans. other than the output shaft, and the fluid orifice, weather its plugged or not but then they were talking about '91-'96 have lube holes in the output shaft. '97 & up DO NOT have lube holes in the output shaft.
Old 04-24-2021 | 10:17 AM
darkirish63's Avatar
This is a 4x2 4L80E
arthursc2 (04-24-2021)
Noah Burns
11-09-2013 07:55 PM
Pollo432
05-26-2013 05:29 PM
supercustom
04-19-2013 10:47 AM
droppedchev
11-01-2010 07:52 PM
95LS1TA
12-15-2004 06:58 PM
