2001 SCSB 4.8 4x4 to AWD swap
Old 02-12-2011, 01:01 AM
  #31
Midnight's Avatar
On a 4x4, the hubs don't lock, but actually the right side axle is a two piece that locks together, while the AWD has a one piece axle which to me seems like it would be stronger
Yep, thats what i meant haha, thanks for clearing that up man.
Old 02-12-2011, 09:16 AM
  #32
Originally Posted by 1Bear
The option code for the NVG-149 would have been NP3, but as far as the noise is concerned, it could be as simple as you are causing the viscous coupler to go into hump mode if you’re spinning the tires viscously or a stretched chain. These things are pretty reliable, but they do suffer from the same type of issues that regular 4WD cases have plus the non-typical viscous coupler failure from time to time. It’s not 100% as anything can wear out, but usually failures of the coupler arise from abuse, whether it be from lack of servicing, causing the unit to overheat or humping the unit also causing it to overheat.
Thanks for the info.
I did a search on NVG-149 and came up with this great article, if anyone is interested.
http://www.silveradoss.com/forums/to...fer-case-info/
It seems that moderate amounts of humping are normal
Old 02-12-2011, 02:43 PM
  #33
Midnight's Avatar
I didn't have to do anything electronic with my swap. I had a manual floor shift four wheel drive transfer case. So all I did was remove the transfer case and front differential, and install the NVG-149 and front diff out of an AWD truck, plugged in the speed sensor to the port on the T-case and that was it, done.
Old 02-23-2011, 07:08 PM
  #34
cfaluck13's Avatar
HD front end with Z71 tahoe valence and fogs
Size:  76.2 KB[/QUOTE]
Hey im tryin to put the same nose on my '02. did you modify the 1500 bumper to fit the HD cover piece? Or did you use the whole HD bumper?
Old 02-23-2011, 07:11 PM
  #35
Midnight's Avatar
Do a search man, theres a lot more into this swap then just bolting parts on. They're the same ******* bumper. You have to modify the bumper brackets by lowering them about an inch and a half, cut and re-weld.
Old 02-24-2011, 05:03 AM
  #36
cfaluck13's Avatar
well i have, and there are several different ways of doin it. i was just curious of how you did yours, looks good
Old 02-24-2011, 02:39 PM
  #37
Midnight's Avatar
Its really easy, just cut the bumper brackets off and lower them. Then weld them on again. I put the bumper where I wanted it and then welded accordingly. Know what I mean?
Old 05-07-2011, 01:44 PM
  #38
Midnight's Avatar
I'm looking to get the front/rear differentials redone with 4.10's. Can anybody suggest a good kit to go with? I'm looking at the Eaton units right now.
Old 05-07-2011, 02:36 PM
  #39
11 Second Hall Moniter
AKlowriderZ71's Avatar
You won't beat Ron's Machining, even including the shipping. That's where I got my stuff, he blew everybody elses prices out of the water, even with my wholesale discounts.
Old 05-29-2011, 01:12 PM
  #40
Midnight's Avatar
Debating on 4.10's or sticking with the 3.73's. Might just stick with the 3.73's so I can still go fast on the highway, but I'm sure some of you 4.10 guys will say otherwise
Quick Reply: 2001 SCSB 4.8 4x4 to AWD swap
