2001 SCSB 4.8 4x4 to AWD swap
#51
You can do all those things, do a search for nvg-149 and 4l80 swap. You have to get a different output shaft so the 80e OS works with the nvg149 t-case.
Imo, get a built 4L60/4L65 from FLT or someone else and then you don't have to worry about all the conversion stuff.
SS trucks had 4.10 front differentials so look at AWD tahoe's or Denali's maybe.
#52
After reading up on the subject, I think I may go the AWD route. I've ot a very similar truck as the OP. I want o keep my 3.73's. What year vehicles do I have to look for exactly to find 3.73 AWD front end and it was the Denali and SS trucks that had AWD, right?
What's a ballpark figure on price for the parts needed for the swap?
Oh, can you adapt the AWD transfer case to work with the 4L80E?
Thanks!
Thanks!
EAD performance makes an input gear for the nvg149. That's what I am using with my 4L80e.
#53
Charlie Murphy!
Thanks for the reply. Ive read wherepeople claimed that locking into 4hi is weaker than replacing the front end with the AWD setup. I personally don't see how it could be all that bad, but the 4wd front axle was not intended to be ran all the time either.
Have you had any problems running it that way?
There isn't any bearing differences or anything between the AWD front end and the 4wd front end is there?
If not, I'll just lock it into 4hi and swap in an AWD transfer case and driveline.
The rear drive line is the same length between the two transfer cases right?
#59
ok so i just read this whole thread. ive been contemplating the same swap. i have owned awd trucks before, but never done the swap. how much better/worse or fun/buzzkill is the awd vs 2wd under high hsp?
