2001 SCSB 4.8 4x4 to AWD swap
Old 03-31-2012, 08:18 AM
  #61
Originally Posted by 454ss08
ok so i just read this whole thread. ive been contemplating the same swap. i have owned awd trucks before, but never done the swap. how much better/worse or fun/buzzkill is the awd vs 2wd under high hsp?
I didn't swap, my suburban came with AWD, but I can give an answer to your questions.
I have mixed feelings about the AWD. It depends which driving mode is more important to you. It's great for drivability, pulling out into traffic, bad weather, you just punch it and you're moving quickly. Also you get the benefit of if the roads are mostly clean but patchy slipperiness, I'm in 4x4, whereas without AWD you don't put it in 4wd because of the clean parts of the road. I like it alot for those.
Of course, on the other hand, if you want to do the occasional burnout/drift/donut, you're out of luck, unless you have lots more hp than I have. For me, I can live with that though since I can hop in my LS1 Z28 or on my XR650R if I'm feeling frisky :drive
Old 03-06-2020, 11:10 PM
  #62
Registered User
Emma's Avatar
I know this thread is old as ****, but I just finished my AWD conversion on my 03 silverado, new rh axle tube & shaft and all that, unplugged the tccm and still have a service 4wd message. Ever happen to any of you guys, if so what’d you find?
Old 03-07-2020, 04:01 PM
  #63
arthursc2's Avatar
Received 1,497 Likes on 1,097 Posts
plug it back in and plug in the encoder and ziptie it to the frame. Easy mode
hard mode: look up the wiring changes needed for the 241 swap. Been years since I did this, but there are some wiring changes to perform at the TCCM to keep the light off, but I still have my TCCM and I expect you will also need to keep yours unless you reprogram your BCM as not a 4x4
Old 03-07-2020, 04:06 PM
  #64
arthursc2's Avatar
Your truck is also looking for the CAD servo up front. I think we can put a resistor in there to appease that feedback loop. But it's 4 wires up there and I don't which ones are the check and which ones are motion, or if they are even broken down like that
Old 03-07-2020, 04:08 PM
  #65
makes children cry
_zebra's Avatar
well the OP had a manual t-case, so that rules him out for answers.
i never ended up doing mine & kept the 4x4... but mine's also a manual t-case anyway.
Old 03-07-2020, 07:37 PM
  #66
arthursc2's Avatar
So that might be a solution. A same option 2wd BCM or a same option manual t case 4wd BCM
Old 04-09-2020, 03:09 PM
  #67
cammoheng03's Avatar
Default awd to 4wd swap 2005 sierra denali
I have a 2005 gmc sierra denali that is awd and im wanting to convert to 4wd so i can have the option to go 2wd-4hi-4lo . Has anyone done this swap before ? what is all needed and any one have the parts needed for sale?
Old 04-10-2020, 06:35 AM
  #68
adriver's Avatar
You will probably have better luck starting a new thread with a better title for what you want. Search though, I know of at least a couple SUVs that did this. I know one was a Denali, not sure if the other was an escalade.
Old 05-19-2021, 09:06 AM
  #69
kaze_v8's Avatar
Reviving this thread to avoid making a new one.
Im doing an AWD conversion on an OBS, being ignorant to how gearing works, Im not sure what rear gear ratio I have.
My question is, since im doing a 4.10 up front, would it affect my TC if i have something other than a 4.10 out rear?
Those SS rear axles are hard to come by.
Old 05-19-2021, 09:15 AM
  #70
Charlie Murphy!
iregret's Avatar
Front and rear gear ratios must match.
Quick Reply: 2001 SCSB 4.8 4x4 to AWD swap
